Would my 4 channel rear work in my 3 channel car
Old 05-10-2006, 02:14 PM
CAMJAG's Avatar
Default Would my 4 channel rear work in my 3 channel car
Can I put a ASR rear in my car if it dosent have ASR? Would I just let the connectors hang for the ASR or can I just take them off? What would I have to do if anything?
Also I want to order gears and a install kit, would I have to order it as a 4 channel with ASR or a 3 channel without ASR?
Old 05-10-2006, 02:19 PM
Studytime's Avatar
If you want your ABS to work, then you can't do it. There's not a drilled boss for the ABS plug on top of the 4-channel pumpkin. If you have connections at a machine shop, this can be remedied, but it would be better to get a 3-channel rear to start with.
Ben T.
Old 05-11-2006, 08:49 AM
CAMJAG's Avatar
Ok so what does the machine shop actually have to do, and is it expensive?
Old 05-11-2006, 06:39 PM
CAMJAG's Avatar
Does anyone have any experience with this same situation I have. I mean if I just put the rear in my car what would happen? Would it work normal but it just would not have ABS at the rear brakes? Would it throw a brake light on? I just dont want to do all this work and All I want to do with the rear is just put a set of 4.10s in it with a complete ratech install kit and a ta cover and thats that. The stock rear thats in the car now would just sit around and wait till I blow this one up. If anyone could just give me some answers before I run into them myself and hope its all good in the end
Old 05-12-2006, 08:28 AM
keliente's Avatar
You wouldn't have ABS at all, the controller needs to see all the sensors operating correctly.
What will happen? The ABS INOP and ASR OFF (if so equipped) lights will come on and stay on the whole time. They're kind of annoying, mine have been on since I broke my 10 bolt, and I have no idea why.
What about this - put the 4.10s in the rear end you have now, and keep the other 4 channel rear end as a backup. That way you can keep your ABS and only go without it if absolutely necessary.
Old 05-12-2006, 09:50 AM
CAMJAG's Avatar
Yea I really wanted to just keep the factory rear to the side but maybe ill just sell this one and look for a 3 channel. I acually have the setup off a 2000 ss that had ASR can I just install the ASR on my car and then not have a problem
Old 05-12-2006, 09:57 AM
alamantia's Avatar
Thts wierd you wrote this post. I have a 3-channel in my car (non-ASR) and I'm picking up a 4-channel tomorrow. If I just drill and tap the housing on the 4-channel that I am purchasing, can I simply swap over the ABS control from the 3-channel in my car to the 4-channel rear I am buying??
Old 05-12-2006, 09:59 AM
keliente's Avatar
No because there will not be a tone ring on the differential of the 4 series rear you are buying, thus the sensor will have no signal to pick up on.
Old 05-12-2006, 10:09 AM
CAMJAG's Avatar
Can I install the ASR setup on my car with the 4 channel rear? If so I would just do that instead
Old 05-12-2006, 10:19 AM
keliente's Avatar
I guess mechanically you would just need to have the TCS harness, but I would imagine that the abs controllers are different. And if you did have to replace the controller it would probably not be worth the $$ to do so.
Old 05-12-2006, 10:51 AM
CAMJAG's Avatar
I have the controler. I have everything off the 2000 SS
Old 05-12-2006, 11:09 AM
alamantia's Avatar
What is involved in adding the traction control to a non tracton controlled car. Rear, Controler and dash switch?
Old 05-12-2006, 11:23 AM
CAMJAG's Avatar
The controller, rear end, harness for the rear, ASR button, and I think thats it im not sure I have to look at all the stuff I have.
Old 05-12-2006, 03:30 PM
CAMJAG's Avatar
Has anyone converted there car over to ASR?
Old 10-24-2008, 06:03 AM
drain89's Avatar
I'd like to know this also.
