C-clip problems
Old 05-10-2006, 08:26 PM
Toxic_WS6's Avatar
Default C-clip problems
Anyone have problems removing c-clips? I thought that these were just supposed to slip out? Seems like I can't get the axles to go in enough, even with prying. Anyone have any tips?
Old 05-10-2006, 08:30 PM
gr8one99SS's Avatar
if you have traction control (4CH rear) then you must remove the abs sensor on the back of the backing plates it a single bolt.
Old 05-10-2006, 08:53 PM
Toxic_WS6's Avatar
Thanks, I will try it tommorrow
Old 08-11-2010, 09:09 PM
Snake_Skinner's Avatar
and if you have a 3 channel rear?
Old 08-11-2010, 10:02 PM
fastsspr's Avatar
With the 3 channel that not happend.
Old 08-11-2010, 10:36 PM
Spartan7's Avatar
Then they should practically fall out when you push the axles in.
Old 08-11-2010, 11:26 PM
SS SLP2's Avatar
IF still have problem, try pounding on end of axel with dead blow hammer while a helper pry the c clips
Johnny
