posi aditive for a 9 inch
i've got a 9 inch and a pretty new posi in it. im only doing one wheel burn outs and someone mention i could have too much posi additive in it? does that make any sense?
i used 2.5 bottles of redline shock proff gear oil, then most of a bottle of there posi additive(small bottle)
im getting ready to drain and re fill it. how much should i use?
thanks
thanks
did some searching
Compatible with petroluem or synthetic gear oils, this product will significantly reduce the friction break-in of differentials, reducing break-in temps for as much as 50 degrees F. Limited slip or positraction units will often chatter without use of this product or a gear oil with a similar modifier, so add only enough to eliminate the chatter and avoid making the plates or clutches too slippery. thats from redlines site for there posi additives... hopefully i did use too much and changing it out will fix my problem.
