Problems with 12 Bolt
I've had my Moser 12-bolt for about a year and ever since I installed it, it's been clunking when turning slowly. I've always run two bottles of GM limited slip addative but it doesn't seem to help. I'm running 4.11's with 33 spline axles. Is there any way to fix this problem, is it serious and is it even a problem at all or are these Mosers supposed to do that? Also, what can be done about the gear whine? It sounds like I have a coyote riding in my car!
welcome to the world of moser... mine does the same exact thing...its just how it is man. just wait..your axle seals will leak..then the pinion.
if i had to do it all over again i would of kept my 10 bolt or went to a 9 inch
10k miles and 1 axle seal here. Mine started with the clunk and notchiness while turning. I replaced the gear oil and put in new additive. This seems to have helped for now. I have 3.73 gears and not much whine.
Originally Posted by who281
soo if im looking at buying 12-bolt should i go moser or strange or wat>????
