Aren't all 4th gen rear ends posi???
Just curious, because I thought that they were. I bought a complete rear end out of a 2001 camaro that had disc brakes and came with 3.42 gears, but when you turn one wheel, the other wheel spins in the opposite direction. That tells me that it is an open diff. One of the guys that I work with swears up and down that the Torsen diffs act like an open rear until one wheel starts to spin. Can anyone shed some light on this subject??? Thanks for any info!
That's normal for a Torsen diff...
The technical stuff is a bit hard to explain, but as long as you're laying down two patches of rubber, you're golden
Not all 4th gen's had a posi. I believe with the V6 cars it was optional and I've seen many a unhappy buyer after they get a 3.42 gear rear only to find it was from a V6 car and came with the open diff.
It uses Torque Muliiplication for power transfer, which means if there is no traction at all on one wheel, the other one gets all the power since 0 times 0 = 0. Works great for straight line, but sucks for hard cornering, like when you auto-x.
I just installed a rear from an 01 SS that looks like a torsen unit, but spins both the same direction while the rear is elevated.
Thanks for the info guys, it is most appreciated. I was just wondering about it cause the rear end that is in my 98 T/A is a posi and the wheels both spin in the same direction. It isn't that big of a deal if it is an open diff because I am only using it as a temprary fill in until I get my 9 inch built.
