12 bolt gear install
Old 06-25-2006, 08:17 PM
Mustang Hat'r 2's Avatar
Default 12 bolt gear install
Needs some torques specs etc.
Ring gear to carrier? Threadlocker?
Back lash?
Runout limit?
Pinion preload, I'm going to use a solid crush sleeve can you tell me how to shim it to get the right preload and what the preload should be?
I assume the shims, if you don't have enough in there it doesn't get tight and to many you end up having like end play?
Also any idea what the pinion nut size is?
It's a strange 12 4 series carrier, 4.11 gears, 4 channel with 33 spline axles.
Thanks
Old 06-26-2006, 06:57 AM
BudH's Avatar
There's an install document with specs at the end here:
http://www.ringpinion.com/downloads/yukoninstman.pdf
