?'s about 4:10 gears
Ok I'm thinking about gettin the 10-bolt gear kit from TSP. It comes with everything you would need including fluids. I am leaning toward 4:10 gears but keep seeing people talkin about not using them if they are gonna spray. I do plan on sprayin soon but only a 100 shot at most. I am also a 6-speed so I was wondering how much faster the RPM's will raise on 4:10's w/sauce.
Will I not get to use all my power/torque due to having to shift too much?? I want it to be faster but at the same time don't want gears I run through in a block distance. If not 4:10's what should I go with??
I just installed 4.10s last fri and I LOVE them. With that said I cross the traps in 4th with the shift lite on and it's SO close that I let it hit the limiter before I let out Trapping 113 and top speed in 4th w/4.10s is 115@6200.
I am going to spray the car for the first time since installing the 4.10s and I WILL be shiftn to 5th no ands, ifs, or buts about it. If I wasn't getting a cam in the near future where I can bump the limiter up to 6800 I would be very limited with the 4.10s. But damn for a bolt-on car they're freckn badass
