02 WS6 6 speed what would it be like with 4.10s?
I wanna put 4.10s in the rear and I plan on doing more later on so would I wanna upgrade to a bigger rear end? 9 inch or 12 bolt? what is your experiences with the different rear ends and what kind of improvements can I see with the 4.10s?
The Moser 9 inch is about the same price as the Moser 12 bolt. The nine inch is even sturdier, and has a better style of a torque arm mount. For 6 speed cars I recommend the Moser 9 inch. 4.10 gears will give you a noticeable increase in acceleration, and driving around town is made easier. Bob
Originally Posted by CW00BlackTA
What he said and...If you add a cam or aftermarket clutch later, the 4.10s will benefit those mods too. Get the TruTrac differential--works great with no clutches to wear out.
is this like the torsen differential that comes stock in the F-bodies?
