Torquer V.2 and 3.90 or 4.10 in a A4?
Old 07-11-2006, 05:50 PM
BLACKBIRD8200's Avatar
Default Torquer V.2 and 3.90 or 4.10 in a A4?
before everyone says use the seach feature (I ALREADY DID) no luck.
Does anyone run these rear gears in a A4 with a set up like mine?
I ran 12.4 and looking to get into the 11's.
my current rear gear is a 3.42.
I figured with either 4.10 or 3.90's and port and polish TB and an ASP pully
I might run 11.90-80 1/4 et
I know the car has a 12.20 in it as it sits now so all I need is .3 to get in to the 11's. the car also weighs in at 3850 (thats a big bitch).
I don't drive on the high way much at all (only when driving to the track)
and it's not my DD so I'm not worried about gas mileage.
I'm leaning more towards the 3.90 just want some help from folks with similar set ups thanks
Old 07-11-2006, 06:45 PM
DWillTA's Avatar
I have 4.30's in a 6 speed and that is about max without running a taller than stock tire. You being a A4 I would think the 4.10 would be the best choice. What size tire you run?
Dave
Old 07-11-2006, 06:58 PM
26" tire
Old 07-11-2006, 07:10 PM
DWillTA's Avatar
If you are using it as a strip car mostly then 4.10 would probably be the choice. What are you crossing the traps at RPM wise? Might want to take a look at your shift rpm and the rpm you are crossing the traps at. This will tell you alot. You may not have enough rpm to run a 4.10, 26" tall tire, and still not hit the limiter in the 1/4 mile.
Dave
Old 07-11-2006, 07:24 PM
I cross the traps between 4900-5300 in 3rd
I shift at 6500
thats why I was wondering if a 3.90 would work I'd get more into my powerband right?
Old 07-11-2006, 07:51 PM
DWillTA's Avatar
Code:
RPM 	1st	2nd	3rd	4th
500  	3     	6    	9     	13
600  	4     	7    	11   	16
700  	4     	8    	13   	19
800  	5     	9    	15    	21
900  	5     	10   	17   	24
1000 	6    	11   	19   	27
1100 	7    	13   	20   	29
1200 	7    	14  	22   	32
1300 	8    	15 	24    	35
1400 	9    	16 	26    	37
1500 	9    	17 	28 	40
1600 	10   	18 	30 	43
1700 	10   	20 	32 	45
1800 	11   	21 	34 	48
1900 	12   	22 	35 	51
2000 	12   	23 	37 	53
2100 	13   	24 	39 	56
2200 	13   	25 	41 	59
2300 	14   	26 	43 	61
2400 	15   	28 	45 	64
2500 	15   	29 	47 	66
2600 	16   	30 	48 	69
2700 	16   	31 	50 	72
2800 	17   	32 	52 	74
2900 	18   	33 	54 	77
3000 	18   	34 	56 	80
3100 	19   	36 	58 	82
3200 	19   	37 	60 	85
3300 	20   	38 	61 	88
3400 	21   	39 	63 	90
3500 	21   	40 	65 	93
3600 	22   	41 	67 	96
3700 	23   	43 	69 	98
3800 	23   	44 	71 	101
3900 	24   	45 	73 	104
4000 	24   	46 	74 	106
4100 	25   	47 	76 	109
4200 	26   	48 	78 	112
4300 	26   	49 	80 	114
4400 	27   	51 	82 	117
4500 	27   	52 	84 	120
4600 	28   	53 	86 	122
4700 	29   	54 	88 	125
4800 	29   	55 	89 	128
4900 	30   	56 	91 	130
5000 	30   	57 	93 	133
5100 	31   	59 	95 	136
5200 	32   	60 	97 	138
5300 	32   	61 	99 	141
5400 	33   	62 	101 	144
5500 	33   	63 	102 	146
5600 	34   	64 	104 	149
5700 	35   	66 	106 	152
5800 	35   	67 	108 	154
5900 	36   	68 	110 	157
6000 	37   	69 	112 	160
6100 	37   	70 	114 	162
6200 	38   	71 	115 	165
6300 	38   	72 	117 	168
6400 	39   	74 	119 	170
6500 	40   	75 	121	173
A4 with 4.10
Old 07-11-2006, 07:57 PM
DWillTA's Avatar
Code:
RPM 	1st  	2nd  	3rd  	4th
500 	3 	6 	10 	14
600 	4 	7 	12 	17
700 	4 	8 	14 	20
800 	5 	10 	16 	22
900 	6 	11 	18 	25
1000 	6 	12 	20 	28
1100 	7 	13 	22 	31
1200 	8 	14 	23 	34
1300 	8 	16 	25 	36
1400 	9 	17 	27 	39
1500 	10 	18 	29 	42
1600 	10 	19 	31 	45
1700 	11 	21 	33 	48
1800 	12 	22 	35 	50
1900 	12 	23 	37 	53
2000 	13 	24 	39 	56
2100 	13 	25 	41 	59
2200 	14 	27 	43 	62
2300 	15 	28 	45 	64
2400 	15 	29 	47 	67
2500 	16 	30 	49 	70
2600 	17 	31 	51 	73
2700 	17 	33 	53 	75
2800 	18 	34 	55 	78
2900 	19 	35 	57 	81
3000 	19 	36 	59 	84
3100 	20 	37 	61 	87
3200 	20 	39 	63 	89
3300 	21 	40 	65 	92
3400 	22 	41 	67 	95
3500 	22 	42 	69 	98
3600 	23 	43 	70 	101
3700 	24 	45 	72 	103
3800 	24 	46 	74 	106
3900 	25 	47 	76 	109
4000 	26 	48 	78 	112
4100 	26 	50 	80 	115
4200 	27 	51 	82 	117
4300 	28 	52 	84 	120
4400 	28 	53 	86 	123
4500 	29 	54 	88 	126
4600 	29 	56 	90 	129
4700 	30	57 	92 	131
4800 	31	58 	94 	134
4900 	31 	59 	96 	137
5000 	32 	60 	98 	140
5100 	33 	62 	100 	143
5200 	33 	63 	102 	145
5300 	34 	64 	104 	148
5400 	35 	65 	106 	151
5500 	35 	66 	108 	154
5600 	36 	68 	110 	157
5700 	36	69 	112 	159
5800 	37 	70 	114 	162
5900 	38 	71 	115 	165
6000 	38 	72 	117 	168
6100 	39 	74 	119 	171
6200 	40 	75 	121 	173
6300 	40 	76 	123 	176
6400 	41 	77 	125 	179
6500 	42 	79 	127 	182
A4 with 3.90
Dave
Quick Reply: Torquer V.2 and 3.90 or 4.10 in a A4?
