Going to a Steel Drive Shaft
Well I found a company here is Phoenix that will be building me a custom Drive Shaft for $190.00. It will be made of steel because the Aluminum one that I have was damaged because of Faulty workmanship from a company here is AZ.
I will have more of the details of Driveshaft. I do know that it will be thicker walled steel, 3 inch, fully balanced and with u-joints. I just have to take my stock one down to get it measured.
How much power will I loser going to a heavier Driveshaft? Is it really noticable?
8 sec potential, 12 sec slip
Originally Posted by keliente
Hmm if you were going to go steel, why not just get one out of a LS1 car for cheap?
I don't know how much HP you'll lose with a stronger driveshaft, but I know from personal experience you will lose 100% of your HP at the wheels with a weak one
Originally Posted by ChevyChad
LS1 f-bodies are not steel. They come with an aluminum weak driveshaft
Usually the autos with 2.73's came with steel DS. Be prepared to wear out some tailshaft bushings with that heavy sucker and 3.73's. Make sure that thing is balanced like a champ before you run the **** out of it too.
Well most of the ones I see people selling on here are made of steel. I don't want a carbon fiber one. I don't remember what tubing he will be using so I don't know what the difference is.
