Next step up over 4.10's with stock rear??? - LS1TECH
Thread Tools Search this Thread
Old 07-02-2002, 02:08 PM   #1
LS1TECH Sponsor
Default Next step up over 4.10's with stock rear???
I see 4.10's for sale and I know a little grinding is required with the $99 Torsen dealie from SLP... but whats the next step up?
Will they work with the torsen unit? What is required to make them work?
I wouldn't mind a cheap spool or locker of some sort. My car is no where near stock anyway so I'm not worried about driveability.
Thanks.
Magnus is offline   Reply With Quote
Old 07-02-2002, 03:08 PM   #2
LS1Tech Co-Founder
Nine Ball's Avatar
Default Re: Next step up over 4.10's with stock rear???
Don't waste money "upgrading" the stock rear. As you go up in gear ratios, the gear sets get weaker and will break easier. This is because the pinion gets smaller and smaller.
4.30s would be the next step. I'd rather put that money into a 12-bolt though.
Tony
Nine Ball is offline   Reply With Quote
Old 07-02-2002, 03:34 PM   #3
LS1TECH Sponsor
I have a V6 so I don't have to worry as much about breaking the gears. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I'm shooting for 12's NA. Gear will definately help.
Old 07-02-2002, 04:00 PM   #4
LS1TECH Sponsor
How much work is required to fit the 4.30's on the torsen LSD?
Would 4.30's be capable of handling a 1.6 60'? My car doesn't hit THAT hard but it does hit.
Perhaps there is a cheaper carrier method to fit 4.10's and 4.30's? I don't mind a spool/locker setup... ???
Old 07-02-2002, 06:23 PM   #5
Fireball's Avatar
I haven't seen 4.30s for the 7.5 rear. Only 4.56s <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Fireball is offline   Reply With Quote
Old 07-02-2002, 07:02 PM   #6
LS1TECH Sponsor
Ok.. Since I only plan to spin the motor to 6500 or so I'm gonna stick with 4.10's..
Thanks for the help once again!
<small>[ July 02, 2002, 09:25 PM: Message edited by: Magnus ]</small>
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
