Driveshaft for 9 inch Moser in 94 F body - LS1TECH
Thread Tools Search this Thread
Old 03-30-2007, 06:02 PM   #1
Default Driveshaft for 9 inch Moser in 94 F body
Does the driveshaft length remain the same when installing a 9 inch in and F-body? I have a 3 1/2" aluminum with 1350 u joints that I would like to use, but it is one inch shorter then the stock aluminum one I have.
Any info or help would be greatly appreciated.
bitemyss is offline   Reply With Quote
Old 03-31-2007, 11:41 PM   #2
94Z28Joe's Avatar
I'm currently using my stock steel one broke the 1le one a had
94Z28Joe is offline   Reply With Quote
Old 04-02-2007, 12:11 PM   #3
EPP
Question
Yes, the driveshaft length remains the same. I don't think I would use your 3.5" one though if it is one inch shorter than stock. Bob
EPP is offline   Reply With Quote
Old 04-21-2007, 12:51 AM   #4
pyronotic138's Avatar
i just installed a 9 inch and my driveshaft doesnt fit. i need it to be like 1 inch shorter for a guaranteed clearance. with it in the car right now i have about 1/4 inch while its on a lift. and i know your supposed to allow for 1/2 to 3/4. lemme know if anyone has an oppinon on this
pyronotic138 is offline   Reply With Quote
Old 04-21-2007, 05:53 AM   #5
EPP
Smile
Quote:
It is probably because you have the rear unloaded. Put the car on the ground, or jack the rear up, and then the stock driveshaft should fit. Bob
Related Topics
Thread Thread Starter Forum Replies Last Post
carbon fiber driveshaft ls1 intakes ls2 dude Parts Classifieds 3 10-19-2014 09:06 PM
LS swap in Gen 3 Nova Driveshaft question romancommander Conversions & Hybrids 13 02-11-2014 03:23 PM
What driveshaft is 64.5 inches or bigger? Vetteman61 Conversions & Hybrids 9 06-30-2013 05:10 PM
Aftermarket Aluminum vs. chromoly driveshaft? raymond mckinney Gears & Axles 12 06-02-2011 08:20 PM
Fixed my Moser 9 inch vibration problem finally!! real82it Gears & Axles 2 07-05-2009 05:54 PM
Tags
02, 9, 9inch, body, drive, driveshaft, f0body, fbody, inch, install, joint, length, moser, shaft, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
