10 bolt rearend leak, easy to fix?
Old 04-03-2007, 10:49 PM
ibanez7's Avatar
Default 10 bolt rearend leak, easy to fix?
yes just like all 10bolts my pinion seal is leaking...
how hard is that to fix?
Old 04-04-2007, 07:14 AM
Camaro_freak's Avatar
Wow, someone else from Crystal Lake is on here. Changing the seal isn't that hard. I just replaced mine last week when I installed new gears.
1. Disconnect the driveshaft from the yoke.
2. Use a dremel to make a small mark on both the pinion nut and the pinion shaft to align them perfectly when you put the nut back on. Also note how many threads are visible past the nut.
3. Remove pinion nut with a 1-1/4" impact gun
4. Pry the yoke off the pinion shaft
5. Pry out the seal
6. Install new seal, yoke, and nut. Make sure you don't over tighten the pinion nut or you will have major problems to deal with. Basically you'd have to disassemble the rear end to replace the crush collar. You should also use red loctite on the pinion nut to make sure it doesn't loosen over time. Just don't tighten the nut past the mark you made in step 2, and make sure the same number of threads are showing.
7. Hook up the driveshaft and you should be good to go.
Old 04-04-2007, 09:59 AM
ibanez7's Avatar
cool thanks dude!!!
more then likely we have seen eachothers cars.
I go to the downtown car show every night when its going! what about you!
Old 04-04-2007, 10:07 AM
Actually I've never been to the car show before. Maybe I'll head down there sometime.
Old 04-04-2007, 10:25 AM
ibanez7's Avatar
its actually a good time. I'm usually there with about 4 other f-bodies!
Old 04-04-2007, 12:15 PM
alamantia's Avatar
5. Pry out the seal
perfict write up just a few additional things you may want to consider is checking teh back of the old seal to make sure the spring is there, sometimes the springs break and fall into the rear just in front of the outter bearing thus releasing pressure on the seal causing it to leak, most times its just old though. If there is indeed a spring in there make sure to get it out. Id also invest in a scotch brite and cleaning out the housing where the old seal was to get it free of any rust and debris, also polish the area of the yoke that rides on the seal with the scotch brite. Additionaly get some 3M weather seal and run a small bead around the new seal so where it gets pressed into the housing, apply a little grease to the splines of the pinion where the yoke slides over and apply a little grease to the seal surface which rides on the yoke so the new seal doesnt burn out.
Old 04-04-2007, 12:53 PM
ibanez7's Avatar
excellent additional info!!!
Old 04-04-2007, 01:03 PM
ibanez7's Avatar
however though..
is the pinion seal, once piece or 2 peices... damn gm part dealers dont know which one goes on the car! I wanted to buy it before I pull mine off!! LOL
Quick Reply: 10 bolt rearend leak, easy to fix?
