Could I benefit from a gear?
Old 04-06-2007, 06:43 PM
keliente's Avatar
Default Could I benefit from a gear?
I've got a 99 A4 with a 3600 stall, shift kit, cooler, headers and a cam.
Before the cam/headers, the gear seemed pretty optimal as far as crossing the traps at a good RPM. Now though it seems like it lacks a little. It has the 3.23 gears. In the 1/8th I am in third at 4900 rpms, and at the 1/4th track I am at 5500. Would it be wise to switch up to a 3.73 or a 3.90?
Old 04-06-2007, 09:06 PM
Ragtop 99's Avatar
3.73s with a stall are good for .1 and 1 mph in the quarter. 3.90s might get another .02 but could be worth more if you are going to run a bigger than stock tire. 3.90s are nice for NA, but if you might add spray, stay with the 3.73s.
If your traction now is borderline, 3.73s+ will push you into needing more tire.
Old 04-07-2007, 10:05 AM
Internet Mechanic
BlackScreaminMachine's Avatar
^ Thats what I was feeling, all out 1/4 really would benefit from 3.90's. As long as you can rev the car out so your not going into 4th at the end of the 1/4
Old 04-15-2007, 01:01 PM
jlashley2001ss's Avatar
what about 3.42 or is that not even worth it since he already has 3.23 gears?
Old 04-16-2007, 05:56 PM
LS1 Eddie's Avatar
Not worth it.
