rear end whine??
Old 04-12-2007, 03:34 PM
speedydog5's Avatar
Default rear end whine??
is it commen on a 2000 T/A ws6 6sp to have a rear end whine to it ,if not what could cause it,looking to buy one and owner states its commen on them,
Old 04-12-2007, 08:44 PM
alamantia's Avatar
it is common. There are factors which contribute to them whining, lack of lube, pitted carrier or pinion bearings, gear swap, abuse etc.
Old 04-20-2007, 01:28 PM
2000WS6Vert's Avatar
Any way to fix it other than replacing the rear end? For example, if it's the bearings, can they be replaced?
Old 04-20-2007, 04:09 PM
BLKWS.6's Avatar
My WS6 didn't whine until we replaced the pinion bearing (had to re-shim obviously) and the different wear-pattern caused a whine. I am going with 3.73's soon to correct said issue.
Old 04-23-2007, 01:04 PM
My rear end is stock. I did a fluid change around 50k. It was whining almost 2 years before that.
How would I know if it's the gears making the noise or the bearings?
Is it worth it to try and find out? I don't really want to spend 2k on a new upgraded rear end at this point as the car doesn't see the track very often and I'm running street tires.
Old 04-23-2007, 01:17 PM
Internet Mechanic
BlackScreaminMachine's Avatar
I got a pristine 32k rear, 3.42 gears 4 channel abs, will sell for 350 + shipping, rear end is crated up and ready to ship, just need shipping address.
