s-10 rear swap
s-10 rear swap
I have a few questions, I have an '02 camaro with 2.73's I took a late-model bravada rear end apart with 3.73s. I think the carriers are different, but not sure. If they aren't would i be able to put the whole limited slip with the gears into my rearend? Is the spline the same between them? I have heard the limited slip in those are different and can suck. Please help! Thanks!
they are called an eaton gov-lok and are a half assed locker, but then tend to explode and frag rear ends at the frist sign of abuse.
ive got a picture of what mine did back in the day on my blazer. ill post it if you like
I was afraid of that. I saw the limited slip and it is that type. It sounded like it might be tough on the diff. I might stay away from it and bite the bullet and spend the money on a new set of gears. Is there a way to make series 3 carrier gears fit onto a series 2?? I didnt think so, but its worth a shot. Thanks for the input! If you have the pics handy, i would like to see them, or else no big deal.
wow, i'm not throwing that in my rear end. I'll probably go through it anyways, but i dont want it to be that quick!! I'm gonna buy a new set of gears i'm thinking. I was thinking richmond, any other gears anyone would recommend??? Thanks for the pics tippmann!
'01 ws6- when saying the gears are the same, do you mean the gears out of the s-10 will fit my series 2 carrier?? i'm a little confused. if they will fit, i will just rob the gears out of the rear end, but i thought they wouldnt fit on a series 2.
3.73 is a 3 series gear
3.08 ias a 2 series and so on
