Thinking about 4.10's (yes I read sticky, and did some searching)
Thinking about doing 4.10's. Is this all I need?
http://www.byunspeed.com/product_inf...726c74d2126329
and
Also, I read this in the sticky: Is this refering to whole rear end or just gears as well? I don't want a dash light blinking at me. Thanks
and
So if you attempt to swap the wrong rear into your car and don't hook it up right, the dash lights will illuminate
I am in the same boat as you. You need a little more than just the gear set. Since your car is a 99, it will have the Torsen differential, and according to what you found, you'd have to go with that paddle kit.
Everything you need is available here in a nice little package....
http://www.thunderracing.com/catalog...&vid=3&pcid=68
Price looks higher, but it isn't. If you only get the gears from Thunder Racing, Motive gears for example, they'll only cost around 190. But you do need all the other stuff, like carrier bearings, shims, fluids, etc.. Check their website out some more if you don't want the performance cover.
Manny
Manny
99's for sure have the Torsen diff? So if I just get that setup from Thunder you're talking about I should be good right? That seems like a pretty good deal if it comes with everything I need.
What about the Brake sensor cause my dash lights to go off (post #1)?
So if I get this it will have everything I need?
http://www.thunderracing.com/catalo...p&vid=3&pcid=68
looks like it all bro! putting 4.10s in my car soon as well, I bought the richmond 4.10s from a buddy who had just put them in his car and then broke and axel and the installation kit from Ratech
Couple more q's guys. Did some more reading in the sticky. If my car is a torsen rear then I will need a paddle kit right?
Also, if it is a Torsen rear I don't need the limited slip additive, correct?
Were all 99's Torsen unless the option from SLP was taken?
Just bought this package with 4.10's and the GM gears!
Anything else to get it installed?
How much more was it to go with the GM gears?
Originally Posted by MannyZ28
Did you order online or did you call to order? When you call, they give you good tech advice. Right now you're a step ahead of me, you ordered yours already...hehe....but yeah, in theory, you have everything.
After they are installed I have to tune the computer to get the Speedo and Tach to read correctly right?
Originally Posted by jshababy23
yeah, I said I was going to get mine re-calibrated but I still haven't...
They were out of the Motives? Oh crap....hmm...When I called a week a go I was told they only had two of the GM's....and you just bought one....guess I better get on the horn before I have to wait forever. I remember when I installed my cam....they have everything except one minor thing......the cam!!! Had to wait 2 weeks.
Originally Posted by alamantia
Motive makes for GM now? what happened to AAM?
