Anyone know the part number for 33 spline Strange axle bearing?
Old 04-22-2007, 05:26 PM
revtime's Avatar
Default Anyone know the part number for 33 spline Strange axle bearing?
I have a Strange 12 bolt with 33 spline axles. the housing end is 3.150 but I am having issues measuring the bore. I think it is 1.540 or 1.550.
This bearing has an Oring around the outside diameter and looks to be a sealed bearing. Its a spool. C clip eliminator but my LT1 backing plates hold the bearing in.
Anyone know the part number I need to order?
Old 04-22-2007, 10:44 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
Edited, sorrry I read that wrong.
Old 04-23-2007, 03:06 AM
revtime's Avatar
Perhaps my nomenclature is all jacked up.
The outside diameter of this bearing has an Oring, I have measured the diameter of the housing the bearing goes into is 3.150 according to my dial calipers. Strange online catalog shows many bearings with the 3.150 diameter but the inner bore size is whats kickin me in the jimmy.
Perhaps I should post a pic of the bearing thats already on the axle.
I need to put backing plates on and will destroy the bearings already on there by pressing them off.
Thats the bearing I need and thats the housing its going into.
Anyone know the part number of that bearing?
Old 04-23-2007, 07:39 AM
LS1Tech Sponsor
I read that wrong as well. The axle bearing number is CR88128R or you can also use the Moser part number 9508B.
Scott @ DLS
Old 04-23-2007, 01:21 PM
revtime's Avatar
Thank you very much.
Any difference in the 2 part numbers? One better than the other?
Old 01-22-2009, 12:44 PM
Tom@SpeedInc's Avatar
Just ordered a set from Napa used bearing number BCA/National 88128RA
Old 01-22-2009, 07:50 PM
studderin's Avatar
frasier whast the OD on the welding/marrage ring whatever ther called is on that PN?
The bearing is a normal set20, you can get the timkin local form autzone for like $25 a size. Some places charger $40 a side or more. Ive used on my strange s60 35spine S/T axles. And a DTS 12bolt.
But the strange setup with the inner seal that keep fuild in the tube only, the welding/marrage ring whatever ther called, tuned down for the seal. I've bought just the strange style welding/marriage rings for $5-7 + shipping from stange.
Old 01-22-2009, 08:40 PM
BadBandit69's Avatar
those are the big ford ends. you should be able to get them at a normal parts store in your town. you just have to ask for axle bearings for a 69 ford pickup i think.
Quick Reply: Anyone know the part number for 33 spline Strange axle bearing?
