whinning noise
whinning noise
Just like it sounds. It's a whinning noise coming from the rear of the car. It does not change pitch much just constant whinning. I have installed adj. panhard rod and Lca's (single rod/poly ends). Any input would be appreciated. I have changed the fluid as well.
It always had a little whin but only at the 60-65 mph range. Now it whins from about 35-80mph range. I also installed a set of 3pnt SFC's as well. All of the components were installed with the suspension loaded. I also checked to ensure that the rear was centered by measuring the distance between the center of the rear wheels and the outer edge of the quarters.
I have a similar sound from my rear end. It sounds like I have snow tires on the rear. I think it's the bearings, but will eventually rebuild the rear and change the 2.73's to 3.73's and a new bearing kit. That should fix things all way around.
Do you have any aftermarket LCA's, PHB or SFC's installed?
