abs light
abs light
Change gears to 3.73 and now light came on.What could it be.I love the new jump from 2.73 now
I have to find out whats going on and also what is the break in period for the gears.
When I did the my gear sway it was supposed to be heat cycled once. Which was drive for a half hour and park it for a couple hours. Other than that they told me to drive it for 500 miles befor I really started to get on it. When you put in the gears did you mess up the abs reluctor ring at all. I would check to make sure its not missing any teeth and make sure its straight.
It was my friend s dad.They own a shop and do differentials and rear end for diesels and some time cars.My fiend told me they did not put it on because it did not fit.It use to have a torsen carrier and I bought a Slp auburn posi.Will it be fine driving.He said they would try to put it back on and that hope it does not break
