driveline soultions
Originally Posted by BlackScreaminMachine
I think its drivetrain solutions. DTS...
Shipping was free for me as long as you get the ford 9 in. and get the four box special. I went with scott because he will warranty the center section for 12 months. If anything happens to it I go through him and not moser which I have heard some bad things about.
LS1Tech Sponsor
Moser sends you the housing, axleshaft's, and TA mount. I assemble the center section to your specs and ship that seperatly. You will need to pull the studs thru for the center section, have your backing plated installed behind the axle bearigs and it pretty much just bolts together. Make sure you clean out the housing with some brake cleaner as well.
