Help with gear for a 2.73 z28
Old 05-15-2007, 12:43 PM
l337_haxs's Avatar
Default Help with gear for a 2.73 z28
The car is: 98 Z28 (A4 with shift kit, i don't know if that makes a difference in the gearing) with the 2.73
I have a 3.73 gear out of a truck (it is for a 10 bolt and it was a 7.5inch 10 bolt) that was barely used and is in pretty good condition. The problem I have is that a couple buddys of mine told me mine may be a series 2 carrier (sp?). If that is true then this gear would be useless for me. So I am now on a hunt for a gear for my car. I really want a 3.73 for acceleration purposes.
Do any of the sponsors sell the gears for my car? If so could you provide me with links to them!
Thanks!
Old 05-15-2007, 12:44 PM
MannyZ28's Avatar
Yes, you definitely do have a 2 series carrier. Just check out the sponsors and see what they have for a 2 series carrier, or call them for tech advice.
Old 05-15-2007, 12:59 PM
NC98Z's Avatar
You can buy a spacer plate and make thoses gears work, but if I were you I would just get a set of aftermarket thick gears. Thats the same thing I run 3:73 thick gears.
Old 05-15-2007, 01:31 PM
l337_haxs's Avatar
I called EPP on lunch here but I got a answering machine
Oh well maybe they can chime in on the message I left on their gear sets.
Thanks for all of the responses!
Old 05-15-2007, 06:29 PM
gollum's Avatar
This is what you need. Gears for a 3.08 and numerically lower carrier.
http://store.summitracing.com/partde...5&autoview=sku
Old 05-15-2007, 07:48 PM
'91firebirdformula's Avatar
i did the same thing. i bought the spacer for about $50. so far so good
Old 05-15-2007, 07:52 PM
koolaid_kid's Avatar
The spacer is not recommended. Strange and Motive both make thick gears for series 2 carriers.
Old 05-16-2007, 08:50 AM
l337_haxs's Avatar
Thanks for the link gollum!!!
