Axleshaft from 95 Formy to 97 T/A????? HELP
So this guy is parting out his 95 Formula and i need a new right axleshaft because its bent, Now would it be possible to use the one from his in my 1997 Trans Am. Should i get the axle# from his and mine to make sure it will work. Thanks
Well when I ordered my moser axles they say that they are for 93-02 f body. So If I was you I would pull the bad one and take it to compare or if he wants a few bucks for it take the risk. You should be able to tell if it will not work by the length or any other significant differences.
