What gear for 1/4
What gear for 1/4
I have a 9 inch i am going to order and still, not ceratin on what gear to get I will have a M6, my engine can spin to 7000, and i will have a 28in tire. I was told by someone that i should gop with a 4.30 and EPP told me to go with a 3.90 or something like that. But most guys with stock tire hieght go with 4.11s so a liol insight will help from more of the experienced
11Second Club
I'm putting down 400HP and have 28" tires, an M6, 4.10s, and a 7k RPM rev limiter. I haven't been to the quarter with the 28s yet, but I'm positive that with my 117ish trap speed I'll be more than fine without shifting 5th. I really wish I had 4.30s because I'm sure I still wouldn't run out of gear, and I could certainly use the extra umph on the launch.
I'll just get a Procharger from Bob instead, though.
4.10s will let you go up to 142 with that setup, 4.3s will let you go 136
You should be fine with the 4.30's but if it sees street time then i would go 4.10's. Of course im saying this without knowing your setup, but i assume you wont be trapping over 140
Go with the 4.30's! I had 4.30's and a 28 inch tall tire and it was perfect! My car revs. to 6700rpm and I didn't run out of gear. I was talked into switching to a 4.10 gear and wish I never did the switch. I plan on switching back to 4.30's as soon as I get some more $! Trust me.......you will not have to switch out of forth!
Originally Posted by BlackScreaminMachine
If no n20, 4.30's will be fine, if you plan on any juice, 4.10's or even 3.73's depending on the shot.
