Ok getting rear end shortly some choices
Ok got my textralia twin disc and got my deposit on APS twins and now figure time to get a rear end.
I have decided can live without abs although some guy has now think found a way to keep it . Going with 9 inch moser. I street drive the car mostly so no spool or locker have to go with true trac. Gears am still undecided. I like a bit more snap off boost so thinking 3.70 but some guys are saying go with 3.50. I am not totally worried about his car being the ultimate drag car as not caging it and it won't be going to track much past 11.5. I plan on 408 or 427 iron block. So with these bigger engines is 3.50 the better choice. Don't do much highway either so don't think need to go lower like 3.23s or 3.08s.
Also choosing between aluminum or iron center ,is the iron much stronger it is cheaper by a bit. But the aluminum looks so pretty and is a bit lighter but not worried about weight a whole lot. Figure have more than enough hp in my combo to not worry about a few pounds.
id advise not getting a moser. ive seen too many people get stiffed from faulty units and moser not backing them up with warrenties. last mont ha guy had one break on him with under 100 miles and the actual john moser i think his name is said too bad soo sad. dana s60 FTMFW
Hmm no they don't offer abs on the moser 9 inch rear ends if you dont' have traction control car which I don't . and thought most people were happy with their moser 9 inch rears. Seems lots are not happy with the strange 12s but want 9 inch not 12 bolt. So guess take my chances. not into dana either.
