Moser 9 inch aluminum or iron center..pros and cons..
Old 05-25-2007, 09:37 PM
MY99TAWS6's Avatar
Default Moser 9 inch aluminum or iron center..pros and cons..
Aside from the price any reason not to get the aluminum moser 9 inch center section. It is a bit lighter but is it weaker than the iron one. I value strength above all over weight. Price is not really an issue.
Old 05-26-2007, 01:46 AM
35th SS's Avatar
this would prolly be preference for anyone.Im running nodular iron for both of mine.Im looking at it for strength.dont care about the weight.
Old 05-26-2007, 05:55 AM
EPP
EPP's Avatar
The iron center has to be stronger, but very few people would ever need the additional strength of the iron housing over the aluminum one. Sort of like the alum block vs iron block debate. How much power are you making? Bob
Old 05-26-2007, 12:30 PM
35th SS's Avatar
I agree with you there.but better having it in there now than you might change your mind later.go iron if I was you.
Quick Reply: Moser 9 inch aluminum or iron center..pros and cons..
