Nine inch install
Old 06-08-2007, 09:26 PM
WS6 SRT-8's Avatar
Default Nine inch install
Aside from crushing my hand when the wrench slipped off the caliper bolt. I'd say it went pretty smooth. Here are some pics.[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] Is it normal for the housing to sit back like this?
Old 06-08-2007, 10:10 PM
Duffster's Avatar
It'll shift forward once you've got the tires on and weight on it. Looks VERY NICE!!! How's the alignment for the LCAs? I see an adjustable torque arm there also. ..which one is it?
Old 06-09-2007, 11:27 AM
WS6 SRT-8's Avatar
It's all UMI stuff. The torque arm is the adj. trans mounted one. The rear is a little noisy. I guess it's the truetrack.
Old 06-09-2007, 01:19 PM
billybadd's Avatar
Man it sucks putting them in on the floor like that. Luckily a buddy of mine owned a lift. I feel for ya.
Old 06-09-2007, 11:07 PM
Duffster's Avatar
If you haven't gotten it together yet, might I suggest, removing the LCA, installing the back part onto the rear end, lowering just enough to access the front part on the body? Thats how I did mine and you can fine-tune the install that way. . .(i.e. lowering/raising as needed and you don't have to get UNDER the car nearly as much. . .)
My two cents
Old 06-10-2007, 10:07 AM
UMI Performance's Avatar
What brand rear end is that? I don't recognize that torque arm mount. Also it looks like they offer different lower control arm holes already built into the rear end?
The rear sitting back is some what normal, thats the worst part about a 9". Once you get the tires on and the weight on it see how it looks. If it still looks like it is in a bind measure how center the wheels are sitting in the wheel wells. If they are not you may need to invest in a set of adjustable lower control arms in order to get the rear end centered.
Ryan
Old 06-10-2007, 11:40 AM
35th SS's Avatar
thats a Currie set-up torque arm mount.running the same setup on my 35th.I agree hes gonna need some adj. lca to correct.
Old 06-10-2007, 12:17 PM
WS6 SRT-8's Avatar
It was built by a shop called "Rear Gears". A fellow by the name of Danny Miller owns the shop. The rear seems to be centered front to rear equally. Just pushed further back than before. The driveshaft he suggested measures 1" longer than stock. He said the pinion yoke is a little shorter than the 10 bolt. Up front, it looks like the torque arm isn't pulled back. It looks like it sits in the same spot as with the 10 bolt. Thanks for the input guys. Keep it coming. Ryan are you just trying to sell me more stuff. My wife will be thrilled.
Old 06-10-2007, 12:19 PM
Maybe
Old 06-10-2007, 12:20 PM
BOTTLEFEDLS1Z's Avatar
How much did that set you back??
Old 06-10-2007, 07:40 PM
00PewterSS's Avatar
I am at pictures 1 and 2 right now. My car doesn't look as clean as yours though, my brake lines are all rusty and crappy.
Anyway, I don't have lower spring isolators. Did those come with your springs or something?
It would be nice if the thing didn't weigh like 300#!
Brian
Old 06-10-2007, 09:23 PM
WS6 SRT-8's Avatar
Yeah, they came with the springs. C'mon, it's not that heavy . I'll gladly trade the weight for a bullet proof rearend though. Good luck on the install. It's not too bad.
Old 06-10-2007, 09:41 PM
00PewterSS's Avatar
Damn now I want little isolators.
Agreed, I will be happy with it....
But, since it isn't that heavy. How about you come over and lug it around. Cause my wife isn't cutting it and I can't seem to lift it by myself!
Brian
Old 06-11-2007, 11:20 AM
WS6 SRT-8's Avatar
If you were a little closer, I'd be happy to lend a hand.
