Pro gear on the street question
Old 06-11-2007, 10:56 AM
10 Second Moderator
Torkman15's Avatar
Default Pro gear on the street question
I have had a 4.56 Richmond Progear in my car for two years only running at the track. I leave @ 6200 RPM with a T-56/Spec4 (10.30s N/A@130) and killed a Richmond street gearset on 28X12.50 ET Streets. That said the GIRLS that run a couple tracks near me say my car is NOT a street car only based on the times I run not based on the fact I still have full interior, both front seats, 90% Factory appearing int cept for Corbeau Forza front seats and 10 point chromo cage.
Question is if I drive my "STREET" car on these pro gears 40 miles or so to get to the track will I hurt them or hurt their intended purpose. Sorry bout the long post but I wanted all the story told so nobody would say just throw it on a trailer.
Old 06-11-2007, 02:59 PM
chicane's Avatar
Your 9310's will NOT live.
"Pro gear" sets are manufactured from high nickel content SAE 9310 steel for increased strength and resistance to shock loads. Additionally, they are heat treated to be softer to absorb the high shock loads in drag racing applications only. Using these gear sets in street applications will result in severe premature gear wear and eventual gear failure.
Put it on the trailer.
Old 06-11-2007, 04:30 PM
lethal93ta's Avatar
thats why I put street gears in mine, the pro gears are just to soft for street driving.
Old 06-11-2007, 07:23 PM
10 Second Moderator
Torkman15's Avatar
If I were running an automatic trans I could make street gears live but I have a T-56 and need to find a setup that is happy running down the road and still surviving 6 grand sidestepping the clutch wheels up passes at the strip. The first gearset I lunched came apart like it was too hard/brittle. It survived 4 trips down the quarter. Maybe it was just a bad set. I want to try a street gear but dont want to have anymore carnage...
Old 06-11-2007, 07:45 PM
chicane's Avatar
Factory OE and some aftermarket sets are 4027 material... and really brittle. They Rockwell at about a 59 to 62 "C".
Aftermarket and most performance 8720 sets are softer and will take more much abuse. They Rockwell at about a 58 to 59 (with the exception of Richmond that maxes out at about 65 "C") ... but ...
The 9310 is even softer. It's in at about 52 to 56 "C".
I would suggest to use a USGear or Percision gear set. I have had the best of luck with them in the same application as yours. I might also go as far as to have the cryo'ed and REM processed.
Old 06-11-2007, 08:58 PM
lethal93ta's Avatar
what for rear do you have? a 12 bolt? might be time for a 9 inch, I dont know to many people that broke even a street gear in a 9 inch.
Old 06-11-2007, 09:25 PM
14 Second Truck Club
mzoomora's Avatar
The Motive Pro Gears are more street friendly and still plenty forgiving to shock loads. They are not intended or designed for street use, but it has been done. I would plan on regular inspections. They designed some gears for Pro-stock NHRA and are getting longer life and no increase in failures. They make a large and small pinion 9" in a 4.57 and you can get them micro polished when you order.
Old 06-11-2007, 11:05 PM
10 Second Moderator
Torkman15's Avatar
OK I'm thinking that new 31 spline Detroit locker Ive had in a box on the shelf for 3 years now might just replace that 12 bolt. Now to soften up the banker for that credit card (I just spent $1300.00 on faceplating my T-56 and another $500.00 on a Mcloud SFI bellhousing) Hmmmm....
Old 06-12-2007, 09:08 AM
10 Second Moderator
Torkman15's Avatar
Default pik of that 4.56 gear
Old 06-12-2007, 11:41 PM
98ws6firebird's Avatar
Damn!!!!
Quick Reply: Pro gear on the street question
