Pros and Cons going from 2.73 to 3.42?
I recently bought a 00 ss with an A4 and 2.73. Been suggested going to a 3.42 would be a good idea. Just wanted to know how it worked for others.
Did it cost anything in MPG for the lower gears, friend tells me the 3.42 is the perfect gear for my stock daily driver car, that I will be happier with them over the 2.73.
Looks like i can get a set installed for about $400 from what he is telling me.
TIA
B
TIA
B
Originally Posted by TORK?
If it's an SS it shouldn't have 2.73's. Pretty sure all SS's and WS6's came with 3.23's.
98 Auburn, 99-02 Torsen
M6 GU6 3.42 Standard
A4 GU2 2.73 Standard
A4 GU5 3.23 Optional (standard gear set with an SS/WS6/Firehawk)
A4 G92 3.15 (Vette optional)
28 Spline Axle 10 bolt rear end
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by MY99TAWS6
Pretty sure the 2.73 cars have no first gear selectable. And the 3.23 do.
the the original poster if you do have 2.73s then make the switch; you'll be very happy with it. When I had the switch in my old Z it really woke the car up.
Maybe the lt1 didn't have the first gear selectable on 2.73 cars. It is 96z28.
