need help asap
Yes you need to buy exhaust clamps. They just mean it's not a direct bolt on because there is no provision for it (hence buying exhaust clamps). I am pretty sure it is 3". Search isn't working, but I did have a how-to on installing the 12 bolt and I think I wrote it down there.
3" exhaust clamps are indeed what you need. You use the U part, and reuse the lower part of your stock sway bar bracket. You need to ream out the lower sway bar brackets slightly out towards the ends. Bob
