Will older 12 bolt (69 Camaro) gears fit a Strange 12 bolt?
Old 06-19-2007, 07:06 PM
SScam68's Avatar
Default Will older 12 bolt (69 Camaro) gears fit a Strange 12 bolt?
As the title says, will they swap over?
Running a Strange 12 bolt with a steel spool.
Old 06-19-2007, 07:24 PM
wrencher
wrencher's Avatar
Yes it is a "car" 12 bolt based design. There is car 12's or truck 12's, thats the difference.
Old 06-19-2007, 08:03 PM
SScam68's Avatar
Thanks!
Old 06-20-2007, 01:42 AM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
I take it you are trying to find something that will run quietly? Also, start out with a .029 pinion shim and see what kinda contact pattern you get. I bet it sets right up with an OEM gear, the aftermarket housings stay true to the OEM pinion centerlines.
