rear end fluid
rear end fluid
alright so ive been reading a lot in the last 24 hours and it seems the reason my rear in is making noise around turns is that i need to add some oil/additives into it. Anyway i was wondering how do i know if i need the additives? im sure i have a LSD but not real sure since i dont have all the production numbers of my car. Also what brand do you recumend on oil/additives? thanks Jerermy
I'm going to be nice and not say "Do a search".
If you go to the local autoparts store, you will see several brands. You need 2 quarts of fluid. If you buy dinosaur fluid, you will need the additive, which your local auto store also carries. If you buy synthetic, it usually has the additive already in there. I use Royal Purple synthentic myself, but most of the brands are fine. You will need the 85w-90, btw. Also change the gasket while you are there.
