Break in with moser gears as simple as 3min on the jack stands?
The moser 3.73s I just put in my strange 12 bolt spool are already broke in, at least that is all the moser break in directions say? It says for drag race just let the car run at 10mph for 2-3min on the jack stands and then let cool, then race. That was easy enough but why does everyone talk about these complicated break in procedures?
Will you ever drive it on the street ?? If so... I would do a full break in.
I dont quiet understand your comment about the gears already being broken in. Were they previously run or did you just read that from some literature ?? If the gear set is new... they havent been broken in.
Honestly, its a crap's shoot. If you absolutely dont care about noise (specifically if its driven on the street) then I'd say go for it. But if not... I would advise you differently.
The proper break in effects not only the gear set, but the differential fluid as well.
Roll the dice...
Roll the dice...
Roll the dice...
Roll the dice...
Good to hear... the more heat cycles you perform, the better. At this point, its more for the lube than for any thing else (heat related brake down)... but the gear set will also benefit from the work hardening as well.
