Moser 9", what all is needed?
Ok, since search is down for me, I figure I will start this thread anew.
its for a 99 m6, will be putting in heads sometime later, but final goal wont be over 500 hp, and its a DD and very rarely will see track, but will be driven spiritedly
Going for a fully assembled package. Tru trak posi, aluminum case, 1350 yoke, 4.11 gears hopefully motive gears.
Is tru trak posi better or worse than the auburn?
I have the ABS and TCS, so would need the 4 channel abs.
Should I keep the oe length wheel studs?
I will also probably be maintaining the stock brakes, but I dont know if I may upgrade to slotted n drilled rotors later on with ceramic pads.
I see some offer sway bar kits and conversion u joint kits.. what are pors n cons of having or not ordering them?
I dont see c clips beng offered, but I thought I heard Ill need some, but no idea what type etc hehe.
I havent nrrowed it down which sponsor I will be purchasing it from yet, before I get that far into it, id rather kinda go in there knowing some of the better parts I want to make sure get included on it.
I do plan on running a cross member adj. TA with the driveshaft loop, which after the EPP post talking abut how afte ra few hard launches 12 bolts tended to get a bit noisy. I am wanting to go with the 9" mainly to keep it a bit quieter and more durable.
Any thoughts or feedback will be much appreciated. I know this has been covered on here in some post or another, but search is down for me still and I will probably be ordering this early next week.
I got all my stuff from Scott at Driveline Solutions. I was very happy with everything. Tru-Trac is way better than an Auburn in my opinion. The Auburn is just clutches where as the Tru-Trac has helical gears. I bought the Moser axle and hosing package, then all you need is a center.
9" doesnt have c-clips...
The downfall to a 9" is you cant retain the ABS and TCS.......
I didnt buy sway bar kit, I just bought some exhaust clamps and made it work.....
You can bolt your stock brakes right up also.....
ABS (3 channel) is not offered with the 9 inch. ABS/TCS (4 channel) is offered.
The Truetrac is much better than the Auburn. No clutches to wear out.
In your case, I would say yes. Your stock lug nuts will work.
The Moser rear is designed to retain all the stock items.
You can save some money by just using two 3.00" exhaust clamps. You use the U part of the clamp, slip it over the axle housing and reuse your stock sway bar bottom bracket, after oblonging the holes out slightly.
The Napa pn# 240 -0447 U Joint will connect your stock driveshaft to the larger 1350 yoke that is supplied on the rearend.
OEM style C Clips break and allow the wheel/tire/axle to exit the rear-end. Most racing classes don't allow c clips. Moser does not use c clips much better to secure the axles at the ends where Moser keeps them in place.
Check out the info I have here.
http://www.exoticperformanceplus.com....html?item=145
Bob
Bob
