2:73 to 3:73 growl/wine when turning right
i have a 98 ts which has 2:73 in it 160k car .. I bought the 3:73 thick gear and master install set for Exotic performance plus "richmond gearset" i bought vavoline durablend 80 90 w oil k&W posi additive. well the guys put the gears in said the little whine would go away as they smoothed out . well as im going down the road i come up on a sweeping right when i go around it the rearend makes like a grind/howling noise i was like ok nevermind... well when i got home i have a hard right corner like 90 degree it made it really loud ... so i have looked up and read on here with no luck .... all i can find is people with pinion whine nothing like this.... to make a long story short they are brand new gears less than 30 miles on them when i make a hard right turn it growls/whines at me .. any input would be greatly appreciated
thanks chris
thanks chris
no i may have put at most 35 miles on them however i just got back agian from a run around the block. when i turn right slow nothing but if im rolling and like a a sudden cut to the right or even weaving back in forth in the lane it makes a noise ... the noise is almost like missing a gear "a buzz grind noise"
well im not an expert on gears...hopefully somebody who is comes in...but to me it sounds like they were not aligned correctly.
thats what my buddy said that one side wasnt shimmed right... he said somthing like if it does it when you turn right the left wasnt shimmed correctly and if it whines when you turn left the right side was not shimmed correctly i hope some one can help lol
are you sure u got 373s for a 2 series carrier? that could be the problem...
yea i ordered them from epp 3.73 thick plus the guys who installed them do that stuff all the time i just do not know anything abour rearends to be able to tell whats wrong
i was reading that online. i gave it to them i hoped they put it in but i guess eveyone makes mistakes... so that additive makes that big of a difference... also will it hurt to drive it easy of course to see if it just needs to break in more as well...
The right side of the carrier shims is loose ,The shims should be tight ,when you turn to the right, the load is put to the left side of the axle or carrier ,witch is pushing the ring gear into the pinion gear, so tighten up the right side carrier shims. and then check the contact pattern with some white grease or paint
posi?
Anyone point at the posi getting to its last legs. Slip then grip if it is getting close to the end of its life. You will only notice this on hard turns at lower speeds. esspecially right turns. Check on that too.
thanks alot guys for the help ... how do i check to see if the posi is getting old? and i paid somthing like 260 shipped from epp for the whole 9 yards
wow..thats a good deal... well atleast i think so.. do you have there link so i can order some?
yea buddy its a hell of a deal i think the guys name is bob or somthing like that... they are also a ls1tech sponsor here is there link http://www.exoticperformanceplus.com/
very fast shipping... we had some billing issues but that was on my end... my billing addy on my card was diff from my home addy
as for the car its back in the shop they think its the synthetic gear oil / or the wheel bearing ill know something this evening.... thanks for all the input guys
well i put good ole cheap oil with the lsd additive and that took the road noise out of the gears but the guy just had to re shim my ring gear... the pinion depth was a little off he said runs like a beast now... i would tell everyone to go 3.73 over 3.42 .... I know making the jump there from 2.73 was well worth the money the car went from strong to a beast.......
thats good to hear! glad to see everything is getting worked out! and im also glad to hear its a really big difference from 273s to 373s.... my car is cammed and the gears seem to last forever and take forever to get into my powerband... ima be doing the swap very soon...
i tell you what i dont even have a shift kit and it chrips 2nd... i still need to get a handheld and do some tuning .... All i have its smooth bellows, mti clear lid, and flowmaster "mellowtone" exhaust... I can only imagine a cammed car.... only down side is it throws your speedo way off lol at highway speed but its all good i just use the little chart till i can get a tune.... keep me posted bro on your swap
cool thanks! yea defnatly need to get them tuned for the rite gear.... it will also add more miles then ur actually driving...so u should get it done quick
