Proper break in of a Moser 9"
Old 07-07-2007, 01:54 AM
ynkssws6's Avatar
Default Proper break in of a Moser 9"
Like the title says. About to drive it tomorrow for the first time *fingers crossed* how do I go about breaking it in? It has 4.11's with True Trac. Thanks!
Old 07-07-2007, 02:14 AM
chicane's Avatar
I recommend 8-10 complete heat cycles... before you start pounding on it.
A complete heat cycle consists of a 15-20 minute drive at freeway speed to saturate the heat... then let it cool down to ambient temperature. The best way to do this is to drive it to work... let it cool all day long... and then drive it home and park it until you go to work the next morning. That's 2 cycles in a day and about ten total in a weeks time. This will virtually eliminate any heat related brakedown in the lube and provide a gradual work hardening of the gear tooth surface.
Old 07-07-2007, 07:28 AM
ynkssws6's Avatar
Thanks, Chicane. Anyone else?
Old 07-07-2007, 11:16 AM
blk00ss's Avatar
I put mine up on jack stands, and went in foward gears for about 15 minutes, varying speeds. Then I went in reverse for around 5 minutes. Put it down, made a few trips up and down the road...then went to the track and beat the hell out of it with 5k clutch dumps on mickey thompson DR's! And still no whine's or howling!
Old 07-07-2007, 12:04 PM
35th SS's Avatar
thats about right how I did mine.
Old 07-07-2007, 02:07 PM
ynkssws6's Avatar
Lol that's awesome!
Old 07-07-2007, 02:47 PM
14 Second Truck Club
mzoomora's Avatar
The first couple of heat cycles are very important with new bearings. I usually do the first couple on stands due to how much heat a new set of bearings along with a new gear can create.
Old 07-07-2007, 05:07 PM
ynkssws6's Avatar
I did the stand method for about 15 minutes forward and then 5 minutes in reverse. I'm letting it cool and will take it on the highway in a few while varying the speed. Thank you to everyone for their input!
Old 07-07-2007, 09:48 PM
35th SS's Avatar
the real test is when you get to your track and beat on it with 5k clutch dump a couple of times.good luck
