Spohn Adjustable Torque Arm Questions
I have a Spohn Adjustable torque arm bar with the short crossmemeber mount.I measured the pinion angle and the driveshaft angle and they were both 0 with the tires on the ground.Is there a specific way to measure it? and is 0 fine or should i go to -1.I have a built motor and a turbo on the car and i have Mickey Thompsons 325x50x15 on the car.Im not sure if the tire size may change the pinion angle or not.
Originally Posted by Exotic Performance Plus
We set them up for a -2 on most cars, meaning the yoke on the rearend is pointed -2 degrees down. Under a load it is going to rotate up. Bob
I have and angle measure finder or whatever you call it.Do i just measure what the rear angle is and adjust it from there or do i do the driveshaft as well.
Coal Mining Director
Just measure the pionion yoke angle and make it - 2 degrees down.
