View Poll Results: What brand of Gears broke in your 10 bolt?
USGear/Strange
3
9.38%
Motive
11
34.38%
AAM/GM
5
15.63%
Richmond
9
28.13%
Other
4
12.50%
Voters: 32. You may not vote on this poll
Old 07-10-2007, 10:59 AM
93redBIRDman's Avatar
Default What brand of Gears broke in your 10 bolt?
Old 07-10-2007, 01:22 PM
jmill96Z's Avatar
Richmond 4.10's exploded in mine. Then I went to Motive 3.42's and they held enough to kill an axle shaft.
Old 07-12-2007, 07:57 PM
keliente's Avatar
Breakage has more to do with setup and other modifications than it does with gear brand. Plus it is not always the gears. I would say at least half of the people who bust a 10 bolt do so in the differential or axles.
Old 07-12-2007, 10:06 PM
00 black ram air's Avatar
I never broke a set of gears don't know what kind they were but I always snapped axles
Old 07-12-2007, 11:34 PM
great421's Avatar
Never snapped my Strange Axles - but I have busted 3 sets of gears though; stock, Motive, and whatever DTS put in my latest 10 bolt...
Ford 9 inch - the solution to my 1-2 shift issues!
Old 07-13-2007, 12:11 AM
jmdale1984's Avatar
I busted stock 3.42's and Richmond 3.73's... haven't busted the Motive 3.90's yet.
Old 07-13-2007, 04:59 PM
Black02SLPSS's Avatar
Anyone runnin the first option?
Old 07-14-2007, 02:52 PM
Blown93Z28's Avatar
Busted my Richmond 3.73's on the 1-2 shift =)
Old 07-14-2007, 06:50 PM
chicane's Avatar
I have had my best results using them to this point... and they have been my gear of choice in everything that I build.
Old 07-15-2007, 08:53 AM
The Professor's Avatar
the poll is deceiving. a lot of people choose motive gears so naturally, it's going to be the highest in the poll. that doesn't mean they're the weakest; it means they're the most popular.
Old 07-15-2007, 04:11 PM
98mysticZ's Avatar
i have broken stock 3.42's and richmond 4.10's
Old 07-16-2007, 06:29 AM
Black FormulaLs1's Avatar
i have broken a set of stock 3;42's a set of motive 3:73's a set of richmond 3:73's * down hill in fourth when the spray hit..3 teeth off the pinion ..gone* now i am on a stock Z28 rear end with 3:42's TA Girdle, moser axles and arp studs...
also GRENADED 2 auburn pro series diffs..i will never again buy an auburn diff.
Old 07-17-2007, 02:32 AM
monzaz's Avatar
Default destruction
I would like to see how many are stick cars and how many people installed there gears. If they were proffesionally installed did you tell the installer? We set backlash tolerances tighter for hard driving at the track and stick cars. The backlash is the slap of the gears and or mesh tightness. Plus set the gears in a slightly more competition pattern set-up . Hope you all have better luck out there. Jim
Old 07-17-2007, 05:35 PM
SuperSam's Avatar
I have broken around three gear sets. Two richmond and a motive.
Old 07-17-2007, 05:54 PM
PONYEATER's Avatar
What company do you work for that you know so much about gears and setup. Not being a smartaXX just trying to get a little background.
Old 07-17-2007, 11:34 PM
monzaz's Avatar
Default rediff builds
I have my own company in akron ohio area.
J D Race and Restoration. I did not want to over advert...seems some forums have rules or just plain do not like people pushing there products on the forums. So trying to stay low key, but still answer some questions when I have some time. Try to get a pulse on what the guys are needing out there.
We specialize in GM muscle cars rears. I have a website I am trying to get moving for information on GM rear diffs and any rear diff questions anyone might have. It has classified section too. I am slowly building the info as my nephew is building it and have to work around a college schedule ...lol. Education first I told him . If he gets time we work on it.
www.jdrace.com
I do not claim to know everything and will not give a BS answer or a guess. If I do not know I will say it, But will try my best to get that answer too. I have learned from many different racers and spent many hours wrenching and disassembling all kinds of GM diffs. I started the business from nothing and narrow custom rears if needed. I have alot of hands on infomation so if you need help try me I am always willing to help out. Jim Mitschke
Any interest in the MOSER 12 bolt rears? I see everyone is going 9" That is a shame... I have to stick with GM . I can try to work out a better price and build using these housings (12 bolt moser) if any of you are interested. They will still be expensive but should be able to get them lower that 2000.00 GEEZ...
Old 07-18-2007, 02:08 PM
N4cer's Avatar
Brand doesn't matter in the 10 bolt. It's the simple fact that there's only 7.625" of room to work with. You can only fit a limited amount of beef in that can. And it's just not enough room to put in enough metal (big enough parts) to hold good power.
Old 07-25-2007, 06:54 PM
nighthawk15's Avatar
It doesn't really matter what brand you get. IMO 4.10s in a 10-bolt isn't even smart if you do anything at all besides fairly easy street driving because they break easy enough to start with.
Old 07-29-2007, 12:45 PM
98trans-am's Avatar
i broke a set of richmond 4.10s and im now on motive 3.73s, i saw summit racing had there own brand of 4.10s i dont know how strong they might be but for 125 bucks im willing to find out.
Hey monzaz, like how much tighter do you set youre backlash? and does it cause any gear noise? or premature gear wear?
