What gears do you guys think 1/4 mile car
Old 11-06-2007, 06:44 PM
WS6 Canada's Avatar
Default What gears do you guys think 1/4 mile car
525 rwhp 625rwtq
28" MT Drag radials
single stage wet kit
M6 trans
9" Moser
full suspension
no internal mods to moter done red line approx 6200
what gears would you recommend???
Thanks
Clint
Old 11-06-2007, 08:05 PM
EPP
EPP's Avatar
3.70 gears. Bob
Old 11-09-2007, 09:33 AM
ss1
ss1's Avatar
I was thinking 3.73's if you were running a 12-bolt, so yes to the 3.70's with a 9". These guys above me know what they're talking about!
Old 11-10-2007, 01:21 AM
z/28guy's Avatar
I want 3:55 they worked real good in my 79 vett .
Old 11-10-2007, 12:50 PM
1BAD98LS1's Avatar
Id say go with 389, i mean your 6 speed and using 28's so you'll need all you can get to get out the hole and being as your 6 speed your naturally gonna run high mph up top
Old 11-10-2007, 01:08 PM
Vintage Iron55's Avatar
Gear the car for the rpm you want to turn at the finish line. Be careful, you will need at least 4.10s to get the car out without slipping the clutch. Especially with those tall tires. I would try 4.30s. High gears like 3.70s cause much abuse to the clutch off the line. If you want the car to leave really well, devide 13.5 by your 1rst gear ratio and that will get you in the ball park. Remember, if you bog the car, you will break parts.
Old 11-12-2007, 01:14 AM
2QUIK4U's Avatar
I would go with 3.70 gears. That is what Im going to be using in my car which makes about the same power. Only differance is my car redlines at 6800rpm.
Old 11-12-2007, 08:41 AM
ss1
ss1's Avatar
At your power level and limited to 6200rpm you're most likely going to have to shift into 5th gear with anything over 3.70's.
I'm guessing if all goes well you'll trap near 130mph?
2QUIK, what size tires are you going to run, 28's or 315's in your sig?
Old 11-12-2007, 03:09 PM
2QUIK4U's Avatar
I run the 315's in my sig currently but I will be switching to a 28" tire for next year.
Old 11-12-2007, 06:13 PM
WS6 Canada's Avatar
Thanx for all the input!!!
The reason i said 6200 RPM limit, is my car is a NO2 car and it starts losing power around 6200 but my limiter is set to 7200 so i can rev higher if needed.
Old 11-13-2007, 11:49 AM
BriancWS6's Avatar
If you can rev it on out to 7kish then without a doubt go with 4.30s with your 6 speed and those 28 inch tires. With 3.70s it would be a TURD!
BTW, you do have at least some better valve springs right? Spinning to 7k plus on the stock valve train is asking for trouble! (valve float)
Old 11-13-2007, 06:25 PM
WS6 Canada's Avatar
Brian i see you have 4.10 gears, what rpm do you have at the end of 1/4
Old 11-13-2007, 08:27 PM
BriancWS6's Avatar
I don't look at the tach, and honestly, it doesnt keep up anyhow. My shift light is set to 6700 and it's not on when I cross the line. I trap 122 on motor. The gear calculator says I should be around 6500-6600. I'm going with 4.30s in my new rear that I hope to have for this upcoming season.
Old 11-13-2007, 10:03 PM
WS6 Canada's Avatar
what size tires you run??
Old 11-13-2007, 10:36 PM
BriancWS6's Avatar
That's with 315/35/17 Nittos. I'm gonna be running 28 inch ET Drags with the new rear and spraying a HEALTHY shot
