gear swap now whine and VIBRATION
Old 11-22-2007, 11:21 AM
BlackZLS1's Avatar
Default gear swap now whine and VIBRATION
I recently had Richmond 4.10's installed in my 10-bolt and now i have the expected whine but theres a vibration starting at around 60-ish mph and progressively gets worse the faster i go. I had absolutely no problems as far as vibration goes before the gear swap (could go up to 160mph with no trouble).
My question is what could cause this vibration?? Im gonna swap in a different driveshaft soon and see if that helps but i dont think it will.
Old 11-22-2007, 11:45 AM
CTSmechanic's Avatar
180 the driveshaft see if that helps if not you can try clocking the yoke differently on the pinion if you get your highsides of run out all lined up it can cause problems... as far as the whine goes you'll just have to live with it aftermarket ring and pinions are built for strength and performance not creature comfort...
Old 11-22-2007, 04:42 PM
BlackZLS1's Avatar
ok i 180'd the driveshaft and it helped alot but it still has some vibration at 100+ mph. would new u-joints help or am i just bein picky? also, could bearing cause this or would they just make noise?
Old 11-22-2007, 04:46 PM
only time it would be a bad u joint is if you move the joint back and forth it isnt smooth rarchety or totally loose...
Old 11-22-2007, 10:11 PM
lilicedout24's Avatar
hey be carefull. mine made a lil noise i thought iw as goin to be ok. went to the track for the 1st time with new set up un tuned and pop goes the weasle right after that. good thing i took it on a trailer so my point being if u dont trust it bring back up! get it fix!
