Paddles???
Paddles???
I'm getting ready to install a set of 4.10:1 ring and pinion in a 4 channel ZT rear end in an 02 SS tomorrow morning. So it has 3.42s currently, and I thought I had everything, but I just read about paddle kits! What exactly are they and can I do the grinding method without worrying about it?
I have a master rebuild kit, sold crush sleeve, a 4.10 ring and pinion I bought in the for sale section here a few years ago in good shape. I also bought the heavy duty aluminum cover from Summit racing with load bolts for the bearing caps.
It is not a shim.
#9 https://ls1tech.com/forums/gears-axles/412366-rear-end-faq.html
If you need a paddle kit and don't want to buy it, some people have just ground down a bit off the paddle or the ring gear to slip it in.
paddle kits are basically 2 thinner versions of the stock paddle.it's mostly used for 4.56 gears some grinding of the stock paddle is ok for 4.10's though.SLP sells them
