Built 10-bolt?
Built 10-bolt?
Just what it says. I am wondering whether anyone has built a 10bolt using moser axles, C-clip elim., performance posi unit, and a T/A studded rear cover for added strength. And what times did you run; or if not on the track how much power power are you putting to the wheels? I am curious to find out seeing as building one looks to be about a third cheaper than a 9'' or 12-bolt. Now I know that the 10-bolt is weak either way, but still Im curious.
SEARCH.
https://ls1tech.com/forums/gears-axles/820541-10-bolt-question.html
https://ls1tech.com/forums/gears-axles/510589-when-will-my-10-bolt-break.html
https://ls1tech.com/forums/gears-axles/689600-10-bolt-question.html
https://ls1tech.com/forums/gears-axles/775331-making-10-bolt-stronger.html
https://ls1tech.com/forums/gears-axles/733255-stock-10-bolt-precautions.html
Jesustapdancingchrist. Why do you want to put $1500 into your subpar 10 bolt (behind an M6 no less) when you can save another grand and be set for life?
