Ford 8.8" and Ford 9" the same rear?
My t-bird and other fords come with a 8.8" ring gear as far as I know. Never had any problem with it. Now I can't imagine my t-bird came with a stronger rear than my Z, but is the 8.8 and the 9" the same rear just the number rounded up? It can't be.
no, ther not the same... only v8 t-birds have 8.8s
8.8 are in mustang GTs explorers some rangers& f150 and crown vics
9'' are in loder trucks early super dutys and late 70s early 80s bronco full size
Ok thanks. And not to be a know it all, but the v6 supercharged super coupe tbird also had the 8.8 because that's what I have.
but anyway, so I'm pretty sure the 8.8" is the ring gear diameter. Is the 9" also the ring gear, but only .2" larger? If so, I imagine it's also heavier in other ways too then. In a slightly different direction, so my brother's 1999 f150 2wd I think has the 8.8, and his 2005 f150 4x4 has the 9 inch? The housing is bigger on the '05 anyway. That sound right?
The other difference between the 8.8s and 9s (besides the size difference) is how the pinion meshes with the ring gear, it hits it lower on the 9". Then the obvious difference of how the whole center section/carrier comes out of the front of the 9" housing vs. the 'normal' way the carrier comes out of the 8.8.
no your brother does not have the nine inch ford stopped making it a while bak its an 8.8 with beefy housing or 9.75" but i think the 9.75 is super dutys only... i used to be a salesman at ford, let me find me old product-knowlege books and ill let u know for sure
