ford 9" setup
I dont think I'd get too worried about being the guinea pig for a speed secret that will likely cause you to have gear problems and excessive noise. Stick with the mfg recomended lash. As I recall, watching the richmond video made me realize how important setting the lash properly is. The gears are made to be run a certain way.
what is your opinion on this?
i had a factory 3.70 ford gear set up at .018 and it never wined or made any noises at all.
i bought a 4.33 motive and set it up at ..012 (specs .008-.012) and it whines so bad you cant even hear yourself talk in the car.
this jegs brand 4.33 has a spec sheet of .008-.010.
Jeff
