Midwest Chassis & Performance fab rearends... new pics - Page 2 - LS1TECH
Thread Tools Search this Thread
Old 12-18-2007, 06:21 AM   #21
blk99camaro's Avatar
SSvert99 could you PM me a price for just the housing/torque arm/mount narrowed 3 inches? Thanks
blk99camaro is offline   Reply With Quote
Old 12-18-2007, 10:08 AM   #22
RAGENZ28's Avatar
Quote:
Originally Posted by SSwanner View Post
i got mine in today as well. thanks eric!!!!
How much did you narrow yours and what rim/tire are you going to run?
RAGENZ28 is offline   Reply With Quote
Old 12-18-2007, 12:09 PM   #23
I'll post some pics of mine once I get it guys. Hopefully its here by weeks end
JWS6 is offline   Reply With Quote
Old 12-18-2007, 01:05 PM   #24
SSwanner's Avatar
[QUOTE=ssvert99;8324544]
glad to see it got there in one piece! how'd that Procharger box work out? i saved a few of those to work with these rearends until i get the packaging thing worked out.
Worked great. there were a couple small dings/scratches on the housing but nothing bad. only thing i would suggest to be perfect would be to wrap the housing in the wrap
SSwanner is offline   Reply With Quote
Old 12-18-2007, 01:36 PM   #25
[QUOTE=SSwanner;8327274]
Quote:
Your housing does look good
I'll be driving the 45 minutes to pick mine up since I happen to live right not too far from Eric
SMKN TA 95 is offline   Reply With Quote
Old 12-18-2007, 02:35 PM   #26
RooRnZ28's Avatar
everything looks kick ***.... i'll be ordering from you as well after the first of the year, so be ready!!
RooRnZ28 is offline   Reply With Quote
Old 12-18-2007, 11:09 PM   #27
LS1Tech Premium Sponsor
ssvert99's Avatar
Quote:
getting excited????? i sent you a pm with tracking #s. better get that car jacked up!
ssvert99 is offline   Reply With Quote
Old 12-19-2007, 07:10 AM   #28
YellowToy/A's Avatar
Eric any change I might have some tracking numbers??? I would love to get my car on jacks.
YellowToy/A is offline   Reply With Quote
Old 12-20-2007, 11:11 PM   #29
ssvert99's Avatar
the new housing is done, went to powder wednesday evening. probably gonna get held up by the holiday, but we'll see what happens. everything is ready, just have to qci the assy and get it to fedex once its in my hands. i'll keep ya posted. thanks.
Old 12-21-2007, 12:56 AM   #30
waterbug1999's Avatar
Is this the same rear that EPP posted up a month or so ago? Didnt they weight it and it was a little heavier then a 12 bolt but less the a normal 9"?
Also, the 2600, is that for yalls TQ arm and the 9'?
I dont think my 10 bolt will keep cuttin 1.4X 60's too much longer.
waterbug1999 is offline   Reply With Quote
Old 12-21-2007, 08:35 AM   #31
Ericbigmac83's Avatar
No, this is his own rear that he made and then started selling when there was so much interest. Probably around the same weigh though as the epp one though
Ericbigmac83 is offline   Reply With Quote
Old 12-21-2007, 10:53 AM   #32
ssvert99's Avatar
hell no its not the same! i actually had the fabricated housings in the f-bodys last spring, but didn't make it public until the summer after we r&d for a while. these were initially the same rearend parts i used in the tube chassis cars i build, other than the 3-1/2 axle tube.
this is completely my own design. the components are cad designed, laser cut and cnc folded here. i assemble and weld them by hand, custom to customers specs.
my full length, braced housing with the new 4 hole lca bracketry is 57 pounds. a complete rearend with a aluminum center section, axles, and brake backing plates is right at 150 pounds.
no strength is sacrificed on these rearends, either. i use 3 inch DOM axle tubing, and the center of the housing has internal gusset plates that the axle tubes run into. the tubes go all the way to the housing studs. its light, and its strong! we now have a specific design, just for the f-body application. 3 and 4 channel abs offered, also. the 4 hole lca brackets, anti-sway brackets, and drain plug are a standard feature at no extra cost on all rearends i do.
next time i talk with Moser i will ask them to weigh a bare housing. the other components are gonna pretty much be the same. i guarantee mine is a bit lighter, though.
Old 12-21-2007, 02:56 PM   #33
LOL... Sorry.
I like the design. I have no ABS so will it be cheaper without ABS then?
I have my spohn TQ arm, will it fit on this 9" or will I have to use yalls TQ arm? And, is the TQ arm incuded in the 2600?
Can you PM a price? No ABS, with aluminum center section and a posi diff.
Thanks.
Old 12-21-2007, 07:32 PM   #34
wrd1972's Avatar
Got mine in last week and everything went together nicely.
Here are some shots of my Midwest 9":
Craftsmanship of this housing is excellent. This thing is built like a @#$%ing tank.
wrd1972 is offline   Reply With Quote
Old 12-21-2007, 09:20 PM   #35
It looks like it has different setting for the LCA mounts? Is that correct?
Old 12-21-2007, 09:46 PM   #36
wrd1972's Avatar
Yes, it has four positions for LCA's and the track arm has 4 positions too. No having to add relocation brackets here.
Old 12-22-2007, 08:03 PM   #37
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
^ Looks awesome! I can't wait to order mine. Why can't tax returns come out around Christmas?
Beaflag VonRathburg is offline   Reply With Quote
Old 12-23-2007, 10:00 AM   #38
Is that rear sway bar part of the package? Neat setup there.
Andy
White.Lightning is offline   Reply With Quote
Old 12-23-2007, 06:58 PM   #39
wrd1972's Avatar
The housing has sway bar mounts already attached, my stock swaybar bolted right up.
Old 12-25-2007, 10:34 AM   #40
These looks awesome Eric! I will hopefully be giving you a call in the Spring.
Grifter is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
02 camaro street/grudge car rdgr8dr78 Vehicle Classifieds 27 03-13-2017 03:41 PM
Midwest chassis, Kooks, Rpm, Afco, Mcleud, Pst, Strange green94z Parts Classifieds 18 02-02-2016 04:14 PM
You wanted it, Strange delivers. The new aluminum HD 9 inch case ssvert99 Gears & Axles 48 08-25-2015 03:47 PM
Rear-end weights - Post what you have EPP Gears & Axles 43 03-05-2010 05:37 AM
Midwest Chassis & Performance fab 9 inch install pics ssvert99 Gears & Axles 41 01-04-2009 11:37 AM
Tags
2002, 98, cars, chassis, complete, ends, fab, midwesat, midwest, moser, rear, rearends, seals, watts, z28
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
