Midwest Chassis & Performance fab rearends... new pics
Old 01-10-2008, 04:18 PM
  #61
RAGENZ28's Avatar
Saw the update interested in a price quote for:
Housing with back brace, narrowed 4.5" per side, small GM (Strange/Moser) housing ends, narrowed 4 hole LCA brackets (not installed) sent loose, as well as spring perches and panhard bracket sent loose.
40 spline Moser axles, solid no lightening, 5/8" studs.
Strange pro or Moser nodular iron center section (not "S" type street version), w/ motive performance gear.
Trans mounted (long) torque arm.
No ABS.
Housing bare (uncoated or painted).
Old 01-10-2008, 09:42 PM
  #62
RAGENZ28's Avatar
Best deal on a fabricated rear I've found
Will be ordering mine when tax time comes
Old 01-10-2008, 09:56 PM
  #63
GregWS6&z28's Avatar
just ordered mine!
-Fabricated 9" housing, w/ tunnel crossmember mounted torque arm, with applicable crossmember and driveshaft loop.
-31 spline Moser axles w/ bearings and 1/2" longer studs, 4-hole relocation brackets
included, and drain plug
-Strange Iron S case w/ Truetrac diff, 3.70 gears
-3 channel abs option installed, all parts semi-gloss black powdercoated except center section which will be painted.
OPTIONS:
-Backbraced
-solid Anti-roll bar and mounts
-completely installed with new backing plates
Thanks Eric! I cant wait
Old 01-10-2008, 10:37 PM
  #64
RAGENZ28's Avatar
Originally Posted by GregWS6&z28
just ordered mine!
OPTIONS:
-Backbraced
Nice stuff, back brace will make it really strong, one day if you ever go really fast and step it up you just just upgrade the axles and center section and the housing is good to go already.
Post a lot of pics when you get it I want to check it out
I'm going to go trans mounted torque arm, back brace, narrowed LCA 4 holes, 40 spline Moser axles, Strange PRO nodular iron center with US Gear and 5/8 studs on mine.
I'm excited already and I haven't even ordered mine
Old 01-10-2008, 11:27 PM
  #65
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Originally Posted by ssvert99
I do offer them at a discount when purchased with a rearend package. Same as a driveshaft, brake package, race anti-sway, etc. the more you buy, the better it gets.
That I did not know. I guess I'm going to be getting some other stuff too when my tax return comes.
Old 01-11-2008, 03:59 AM
  #66
ErikElvis's Avatar
WooHaa whoop *** rear on order!
Old 01-11-2008, 04:05 AM
  #67
jakes4321's Avatar
I cant wait to get mine......
Of course since I had to order my true-trac trough work it is on back order with eaton.
I have everything except the true-trac, it is killin me.
Old 01-12-2008, 08:53 PM
  #68
01 Red WS6's Avatar
I have a dumb question. Is there anyway to make this rearend work with the stock torque arm? My car may see the track just a few times a year and I don't really want to switch from my stock torque arm to another. I just might switch if needed though
Old 01-13-2008, 08:24 AM
  #69
Grifter's Avatar
Right now; no. He doesn't have an adapter bracket made up yet to use the stock style tq arm.
Old 01-13-2008, 11:18 AM
  #70
LS1Tech Premium Sponsor
ssvert99's Avatar
its coming.... be patient!
these new design torque arms have so many benefits compared to a stock or stock type mounted arm. they're lighter, much stronger, adjustable height and angle, and the link is urethane mounted to the crossmembers to eliminate any noise. a great performer on the street or strip, and will clear ory type exhaust or even duals!
Old 01-25-2008, 08:36 AM
  #71
ssvert99's Avatar
Free drainplugs everyday!... free stock style anti-sway brackets installed everyday!... free 4 hole lca relocator bracketry everyday! powdercoating on all components only 100.00 option.. everyday!
international shipping available, also.
fabricated 9 inch rearends available completely assembled, ready to install. the assembly labor is free, but it has to be shipped via truck freight.
we are also offering a ls style brake bracket on a core exchange program. for those of you who don't want to mess with the brake swap or the time to have the car down, we will install a set of reconditioned or new gm caliper brackets and backing plates for a nominal charge. when you get the rearend in your car, simply send me the parts from your original rearend and i will send you a refund on the cores once they are recieved.*used cores pending availability*
thanks to everybody that has ordered these rearends and to those who already have them installed. we appreciate your business.
Old 01-25-2008, 11:22 AM
  #72
Grifter's Avatar
I'll be giving you a call in the Spring Eric!!
Old 01-25-2008, 11:52 AM
  #73
YellowToy/A's Avatar
Eric makes nice stuff. How about the tunnel brace with the driveshaft loop? Is that done?
Old 01-25-2008, 12:29 PM
  #74
daniel6718's Avatar
mine is ordered with a few extra goodies...i cant wait to get it...
Old 01-25-2008, 12:50 PM
  #75
rodcpierce's Avatar
i have talked to Eric numerous times about a rear. He is one of th emost stand up dudes I have ever spoke too. Always willing to answer questions, even though eh knew I didnt have cash at the time to buy one. He will get my business forsure as soon as I have teh cash.
Old 01-25-2008, 01:40 PM
  #76
RooRnZ28's Avatar
ordered mine as well!
Old 01-25-2008, 04:21 PM
  #77
Ericbigmac83's Avatar
I see you went with my idea
Old 01-26-2008, 10:35 AM
  #78
JWS6's Avatar
Some more pics for you Eric! I need to give you a call Monday buddy.
http://www.cardomain.com/member_page...240_4_full.jpg
http://www.cardomain.com/member_page...240_9_full.jpg
http://www.cardomain.com/member_page...240_6_full.jpg
http://www.cardomain.com/member_page...40_10_full.jpg
The following users liked this post:
1SS2NV00 (09-13-2020)
Old 01-26-2008, 11:00 AM
  #79
ssvert99's Avatar
Old 01-26-2008, 11:05 AM
  #80
ssvert99's Avatar
nice... post a pic of the exhaust clearance if you have one. lots of people interested about fabricated rearends and street cars. i know my setup works with exhaust.
call today... i'm available most weekends.
Quick Reply: Midwest Chassis & Performance fab rearends... new pics
