What gears should i go with?
Well guys my car isnt an ls1 fbody! But i still wanted to see what opinions yall had with gears for my iroc. I really dont know what it has right now but what would be the best way to go? Its a 355 with a 700r4 with a small stall. I really wanted to go with 3.73's but dont know how high my rpms will be at highway speeds and it also has overdrive so that should help a lil bit with the rpm's and mpg.
Jeff
They are 275/40/ZR17. And yes sir that is the rear end that i have in my car. So there isnt a 3.73 made for that rearend? Well its basically the same thing right? Not much of a difference? So how much do you sell these for?
http://www.jawsgear.com/store/catalo...oducts_id=1417
3.70 and 3.73 are pretty much the same thing. A person would not be able to feel the difference between the 2 gears. Let me know if you haveany questions.
Jeff
There are no 3.42 or 3.55 gears available for this rearend. You can only get stock used 2.73, 3.08, 3.27 or NEW 3.70. This is a GM 7.75 Borg Warner Rearend not a 7.5/7.625 diff like the late style.
Jeff
Jeff
You can order off our website at .......
http://www.jawsgear.com/store/catalog/product_info.php?cPath=21_105_116&products_id=1417
Jeff
Jeff
Bearings Different size?? Which Bearings?
No axle savers for this application. It uses a bolt in style axle with a tapered wheel bearing not a flat roller bearing. I doubt your axle shafts are bad. You can just buy axle bearings and seals, they run about $100.00 for a set with 2 Bearings & 2 Seals.
Jeff
Its cuz we changed the bearings and seals because it was leaking but we had to get axle savers because the axles had the marks where the bearing had been pressed in and we couldnt run a seal there. So we had to run the axle savers so wont both inner and outter parts of the axle be worn out because of the pressed bearings?
Oh another thing if i get the gears what would be the difference between all the installation kits you sell since they go up in price a good amount compared to the cheaper one?
Installation Kit: This kit uses all high quality components to ensure a smooth set up. Kit includes a pinion seal, crush sleeve (if applicable), complete shim kit, pinion nut, thread locking compound, marking compound and brush.
Bearing Kit: This kit uses Timken bearings and races along with all high quality small parts. Kit includes carrier bearings and races, pinion bearings and races, pinion seal, crush sleeve (if applicable), oil baffles and slingers (if applicable), marking compound and brush.
Master Installation Kit: This kit uses Timken Bearings and Races along with high quality seals and small parts. Included in this kit are carrier bearings and races, pinion bearings and races, pinion seal, complete shim kit, ring gear bolts, pinion nut, crush sleeve (if applicable), oil baffles and slingers (if applicable), Thread locking compound, marking compound with brush, and gasket or sealant.
