Friend's 10 bolt broke
OK I'm helping my friend out, he's got a 00 Z28 M6. Texas Speed 233/233 cam, dumped exaust, no cats, tuned, LS6 intake, ported heads and headers. He just broke the 10 bolt, it lasted him about 2 years and who knows how long before that was the previous owner. never sees the track or slicks. We want to upgrade but not overkill... I've heard if we upgrade the gears and beef up the housing the 10 bolt will work, esp since it never sees any high RPM clutch dumps. He just moved into an apartment and doesn't have much money so we are trying to do a budget setup, which is why the beefed 10 bolt sounds appealing over 12 bolt or 9". what do ya'll think?
gm high performance did a build up i think that cost them 700$ which included all new internals, axles, diff, ring and pinion.. an aftermarket cover, and they welded a bunch of stuff.. pretty much everything you could do and they said they expected it could handle slightly over 400 at the wheels.. Of course they didnt pay for labor.
Just get a used 12 bolt or optimally a 9in.
First thing to find out is what broke. Maybe it was just a gear or posi. You may not have to replace everything in the differential. Pull the cover andsee what is bad and make your decesions from there. Let me know if you have any questions or need any pricing on parts.
Jeff
Jeff
ok we got it apart, appearently the ring and pinion are fine, the straigt teeth next to the ring gear are a little messed up... but the real trouble is inside the carrier. i think those are the spider gears? anyone know what kind of differential is in this car? seeing as it took such a long time to go out, and wasn't the main gears i think we'll just rebuild with some hardened gears and an axle bracing kit. does anyone have a good shop in houston?
Jeff
for the $1,000 or more dollars you will spend on the rebuild and gear swap (New posi unit, Gears, Master rebuild kit, labor, and Materials) you will be almost half way into getting a ford 9" I wouldn't waste the money on the pyle of **** 10 bolt and go strait to the 9". Rule of thumb When dealing with the 10 bolt is to upgrade not rebuild. Just my .02
LS1Tech Premium Sponsor
look at it this way. if you do what you're talking about- gear, good posi, install kit, rear cover, labor, etc. you're talking a minimum 1000. if you break the thing again, then not only have you spent that 1000, but you're gonna have to spend another 2000 minimum to get into a better rearend that won't have the same problem. now that you're at 3000, you can have the best stuff out there. my complete fabricated 9 inch setup with gear, axles, torque arm and crossmember start at 2400. thats less than you're gonna spend if you have to do it twice. and for that matter theres always people selling used 9's or 12 b's to upgrade to the newest stuff.
at this point i say find a used posi and get the thing driveable again, then start saving for a new rearend. and if it's a 3 channel car... i have those available for 9 inch.
This should not even be a issue. If he wants to play, He needs to pay. Step up to the plate and have your buddy get a 9" He will be so happy he did.
I agree, just get the 9" and call it a day. Its more money now but less down the road and you have the security of a nice 9". Whats his dyno numbers...Id guess 435ish, a litttle more if he upgraded to a ls6 intake. I understand the saving part, but doing it once is will save in the long run and you dont have to mess with dropping the rear again.
