What Backspacing?
What Backspacing?
i'm going to put a 9" Rear in my car and its 2" shorter on each side... and i'm gonna get some new Boyds 17-10's what is the backspacin i should choose?
i lookin to go with a big lip rim.. which i think i have to do anyways with the Narrowed rearend
any help would help alot
Thanks Matt
Thanks Matt
Closed Sponsor Account
Using a plump bob helps determine the center of something by hanging a weighted item off of a string and seing where it hangs in relation ship to whatever it is you are trying to center, or measure from. I am sure that did not clear anything up, but if you saw one, you'd see right away what I was talking about...
For instace, you can use the plumb bob method to determine whether or not your rear is centered. It is not the best most accurate way, but it is a good start and can give you a good indication!
