what way would be better 4 tha trex??????
Old 12-19-2007, 06:27 PM
johnster's Avatar
Default what way would be better 4 tha trex??????
i am running the trex, what way would be better?
3.73 with a 26 inch tire or 4.10 with a 28? thanks
Old 12-19-2007, 07:05 PM
Jawsgear's Avatar
You are going to be running about the same rpm no matter which combo you go with. If you can fit it go with the 28 and 4.10.
Old 12-19-2007, 09:29 PM
BigJls1's Avatar
assuming you still have a lockup with overdrive 4l60
at 75mph with the 3.73 you will be close to 2650 rpm
at 75 mph with the 4.10 you be little less than 2700 rpm
so yea the big tire is the best choice.
Old 12-19-2007, 09:49 PM
johnster's Avatar
thanks guys
Old 12-20-2007, 12:01 PM
johnster's Avatar
my car is lowed so i dont think i can run 28s
Old 12-20-2007, 12:25 PM
Jawsgear's Avatar
What tire size can you run. I can use yourtire size to find the best compatible ratio.
Jeff
Old 12-20-2007, 02:19 PM
johnster's Avatar
i was thinking bout runing a 26 inch tire, i have 3.73s now, would that be good 4 the trex or 4.10s with 26 inch tire be better?
Old 12-20-2007, 03:05 PM
import slayer's Avatar
4.10's the t-rex likes those high gears.
Old 12-20-2007, 03:12 PM
El_Diablo's Avatar
4.10s for you. I have 4.11s in my M6 car and I wish I'd gone with 4.30 or 4.56 for that cam. But since noone has said it yet, don't blow your money on gears for a 10 bolt.
Old 12-20-2007, 03:43 PM
Jawsgear's Avatar
What is your trap speed and/or RPM goal for the 1/4 mile?
I am most likely gonna say 3.73 so you do not run out of gear or hit rev limiter butI want to be sure.
Old 12-20-2007, 04:10 PM
johnster's Avatar
there is only a 1/8 mile track where i live, i wont it to go as fast as i can get it ha ha ha ha!
Old 12-20-2007, 04:49 PM
Old 12-20-2007, 05:41 PM
Jawsgear's Avatar
4.10 Ratio then. Have fun with it.
Old 12-20-2007, 05:47 PM
johnster's Avatar
ok thanks
